MTEXT Contents being forced by inline code
Village_Idiot
Village_Idiot
Every now and then I run into text that is tough to edit and impossible to change anything about the way it looks because it is forced via inline code.  (Diesel???)  When I try to edit it I can only select the value and do not even see the code. Any idea why this happens and more importantly, is there a way to correct other than replacing the object with new text?
paullimapa
Since mtext supports various formatting codes and there’s no way to prevent users from implementing them you’ll encounter them
https://www.cadforum.cz/en/text-formatting-codes-in-mtext-objects-tip8640
Paul Li
IT Specialist
@The Office
cadffm
No DIESEL.
This is MTEXT and internal formatting like Font or bold, all what you can do INSIDE MText editor (doubleclick on MTEXT to enter Mtexteditor)
You can also remove all formattings, right click -> remove overrides..
Search for StripMText
But this can force unexpected results.
Sebastian
Village_Idiot
Thanks Paullimapa and cadffm.  I can't believe I never noticed the Mtexteditor mirrors what the code is doing.
FYI - In my version of acad 2023
  • dbl click text to enter editor
  • select/highlight txt
  • right click menu -->Remove Formatting (ctrl+space)
pendean
Community Legend
Community Legend
@Village_Idiot wrote:
.... is there a way to correct other than replacing the object with new text?
You want to find and use this free LISP to remove override formatting from MTEXT you don't like in your DWG file
https://cadsetterout.com/resources/stripmtext-lisp/
and
https://www.google.com/search?q=stripmtext+lisp+for+autocad
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
