- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have used MOVEBAK for the last several releases without any issues. Now installed Acad 2017 and when I try to set the folder to C:\TEMP, I get the error "Not a directory: c:\temp". This works with Acad 2015, but now not with 2017 for some reason.
I am using Windows 7 x64 and my movebak folder is local (c:\temp). I have used the ACAD Reset Tool, but that didn't help, still get the same message. I have even tried entering the "~" when it asks for the directory and then browse to the folder. That does not work either, even though I can see the folder perfectly fine.
I can set the movebak to just c:\, but that is not desirable. I have found this post, but nothing there solved my issue. I also found a post that suggested it was a Windows Search Index issue. The Windows Indexing Service is running and the c:\Temp folder is not excluded from the indexing. I also have the Advanced folder properties set to "Folder is ready for archiving" and "Allow files in this folder to have contents indexed in addition to file properties." None of this helped, obviously.
One step forward, twos steps back......Any suggestions, or am I stuck with putting them all in the C:\ ?
Kirk
