Cannot manage x-refs
Message 1 of 18
I am working in a file with 4 or 5 x-refs.  Until a few days ago, I could manage the x-refs easily.  Now, I am getting this error when trying to load manager:
c:\program files\autodesk\autocad 2015\acxrefesw.arx cannot find a procedure that it needs.
Unknown command "EXTERNALREFERENCES".  Press F1 for help.
Has anyone encountered this?
Replies (17)
Message 2 of 18
rkmcswain
Make sure that DEMANDLOAD = 3.
If so, then you may have to run a repair or reinstall? There are a lot of other threads here in the forums on this topic. None with a clear cut solution.
Also, as a workaround, try the CLASSICXREF command.
Message 3 of 18
CADmonkey_UK_Building_Services
CLASSIC XREF
CLASSIC LAYER
CLASSIC*!
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
Message 4 of 18
RobDraw
Even if it gets the OP what he wants, classic is not a solution. It's a work around at best.
Rob
Message 5 of 18
I confess they might have improved the 'modeless' layers/xrefs since I last had to endure them, but it was a 'classic' case of fixing one problem to create others. I filed a lot of these features as 'bling' a long time ago and have found no compelling reasons to think differently.
Guess how Dynamic Layer Updates fared when I had to manage hundreds if not thousands of Xref layer names? It was a dog and not worth trusting then, and not much use now or then.
Message 6 of 18
RobDraw
Confess? Might? Come on, it's verifiable that they have improved.
Improvements are apt to buggy at first. Refusing to revisit them after the bugs have been shaken out is a classic case of resistance to change.
Again, it's a workaround at best and will, if not already, become obsolete.
Rob
Message 7 of 18
rkmcswain
Hey @Anonymous - did you get this solved? We'd like to know how.
Message 8 of 18
Being extremely productive and very busy means I don't really get the time to discover the latest greatest new way of doing what AutoCAD already does and has done for years.
So I wouldn't know if they've improved it or not, because I haven't revisited it since I turned it off the first time. IMO, all I've missed is yet another opportunity to use more clicks for less function in  an interface that (paradoxically) is simplified, and yet somehow cluttered. Mind you, on occasion I still use xref & layer from the command line because it is quicker.
My maybe-not-so-typical workflow: I work with Acad MEP which has a habit of creating hundreds of layers per construct. In a 'fully coordinated' sheet (one floor of all duct, pipe, cable tray, Arch & Structural @ 1:50), 15 3D 'Constructs' xrefs load into one View, which then Xrefs to a Sheet along with notes, legends, etc. Add all the Layer Overrides which mean a completely different set of  layer states in Constructs, Views, and Sheets. Add Hidden Line removal/ & Line breaks. Regen/Reloading these highly complex documents is no small matter. My biggest MEP projects contains 5 buildings and cover 400-500 sheets which somehow I single-handedly produce from Construction to Record drawings without needing yet more poorly produced 'improvements'.  I resent being a guinea pig for A'desks R&D department in their continuous, desperate attempts to justify their own existence by constantly looking for wheels to re-invent.
Autocad doesn't need new bells & whistles, it needs better ways of informing users where the power is. Some of the questions on this forum illuminate a staggering absence of knowledge of what I'd consider to be fundamental.
Message 9 of 18
RobDraw
No matter the workflow, people are doing themselves a disservice by not using or even being aware of improvements, new tools, and features. Being busy and not having time to learn is bunk.
What if your doctor was still using leeches and snake oil?
Turning the new stuff off and never looking back does not promote efficiency. In fact, it does the opposite. I used to do the same thing. Then, once I started revisiting, I realized how much I was limiting myself. Now, I am always exploring new features and how to use them properly.
Blaming AutoDesk is a diversion from the real problem. People want the easy button, don't take the time to learn best practices, and often refuse to listen to alternative solutions to the way they think things should work.
Rob
Message 10 of 18
I use plenty of new stuff all the time, if it's useful.
'Non-classic' LAYER,& XREF, dialogues suck, both System Resources and figuratively. They are a solution looking for a problem. There are many examples of this.
Message 11 of 18
RobDraw
That's a great example of backwards thinking. Maybe you don't care for them but most of us have used them for years and love their functionality compared to the classic versions.
Rob
Message 12 of 18
Which extra functionality is that exactly?
Like I said before: In my opinion it takes more interactions, adds to desktop clutter, splits your focus and drains system resources. For what?
Message 13 of 18
RobDraw
If you are asking, then you haven't bothered to find out for yourself. Thanks for verifying one of my points. If you had, you would know that there are many references to new features and improvements to existing ones with every release.
Rob
Message 14 of 18
Layer: Aside from being modeless so it just floats around getting in the way I fail to see any difference.It does seem to handle a few thousand layers better than it used to. That said, when I'm Alt-tabbing through a dozen or so open files it's one more thing that needs to update.
Xref: Same information but more spread out, less intuitive and needs more clicks. Also consolidates Image manager, which means it's marginally more efficient. Well done. Attach/Overlay still retains double-click funtionality but is more opaque in it's working, Most Xref functions available in-drawing with a right-click means that the Xref manager is unlikely to be needed for most people, most of the time. It's unlikely to be a high-use dialogue for anyone's workflow. Again it's a solution looking for a problem. It's also less fault-tolerant than the Classic. If you mis-click, you have to wait for the unintended result before undoing.
Message 15 of 18
RobDraw
Glad to see you are making progress. Keep it up.  I'm not going to argue with you about the particulars. I was originally disagreeing with your general response that classic commands are solutions.
BTW, repeating an opinion does not make it any more relevant.
Rob
Message 16 of 18
You have nothing to say because there is nothing to add.
Message 17 of 18
RobDraw
I said I wasn't going to argue. There is plenty that you are missing.
Rob
Message 18 of 18
uh-huh..
