Being extremely productive and very busy means I don't really get the time to discover the latest greatest new way of doing what AutoCAD already does and has done for years.
So I wouldn't know if they've improved it or not, because I haven't revisited it since I turned it off the first time. IMO, all I've missed is yet another opportunity to use more clicks for less function in an interface that (paradoxically) is simplified, and yet somehow cluttered. Mind you, on occasion I still use xref & layer from the command line because it is quicker.
My maybe-not-so-typical workflow: I work with Acad MEP which has a habit of creating hundreds of layers per construct. In a 'fully coordinated' sheet (one floor of all duct, pipe, cable tray, Arch & Structural @ 1:50), 15 3D 'Constructs' xrefs load into one View, which then Xrefs to a Sheet along with notes, legends, etc. Add all the Layer Overrides which mean a completely different set of layer states in Constructs, Views, and Sheets. Add Hidden Line removal/ & Line breaks. Regen/Reloading these highly complex documents is no small matter. My biggest MEP projects contains 5 buildings and cover 400-500 sheets which somehow I single-handedly produce from Construction to Record drawings without needing yet more poorly produced 'improvements'. I resent being a guinea pig for A'desks R&D department in their continuous, desperate attempts to justify their own existence by constantly looking for wheels to re-invent.
Autocad doesn't need new bells & whistles, it needs better ways of informing users where the power is. Some of the questions on this forum illuminate a staggering absence of knowledge of what I'd consider to be fundamental.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
