Move first point (arrowhead) of annotative leader?
anandax
anandax
in Acad 2010 it was possible to move the first point (red rectangle) without moving the text (green rectangle). In Acad 2014 it doesn't work anymore.
There is a possibility to change this?
works in 2015
imadHabash
just review your mleader sittings from MLEADERSTYLE. there you will find - i think from content tab - your need.
Imad Habash
anandax
I'm trying different options and add a new style, but without success. There is no option to change the behavior.
I've uploaded the settings of MLEADERSTYLE. Perhaps you have an idea which option is responsible.
@kentr8: Good to know. Hopefully also in the new version 2016.
imadHabash
would you post just a single mleader as dwg.
Imad Habash
anandax
See attachment. It's an AMNOTE! It seems that AMNOTE is not equal to MLEADER and we have misunderstood us.
FTSRoann
Dear Jakob Meier,
The behavior you are describing is as designed.  The AMNOTE is treated as a single entity within AutoCAD Mechanical.  However, you can adjust the location of the "text" without changing the location of the leader arrow.
Roann Knight
Technical Support Specialist
