AutoCAD Forum
Mouse Wheel Zoom Rates.
11 REPLIES 11
Message 1 of 12
6963 Views, 11 Replies
How do I change the different zoom in and out rates (or percentage) based on the mouse wheel forward and reverse movements?
Eg.
1 forward push of the mouse wheel zooms in 15% and 1 reverse pull zooms out 10%.
I find this feature REALLY USEFUL!
I have this feature in my old AutoCAD 2005 but I can't seem to find the menu/settings.
I'm using AutoCAD 2019 now.
Have searched Google/Youtube and all solutions leads to ZOOMFACTOR which doesn't have this feature.
....or is it from Windows settings?
Andrew.
11 REPLIES 11
Message 2 of 12
ennujozlagam
try to set setting ZOOMFACTOR in your autocad command.
Message 3 of 12
RobDraw
You must have had a 3rd party program. That has never been a feature in AutoCAD, AFAIK.
Rob
Message 4 of 12
jonathanEQSTA
@ennujozlagam is correct. Setting the ZOOMFACTOR will give you the result you want. Values range from 3 to 100.
A value of 10 will increase the zoom by 10% when scrolling up one step. A value of 100 will increase the zoom by 100% (i.e. double the zoom).
EDIT: corrected the low value from 10 to 3.
Message 5 of 12
RobDraw
in reply to: jonathanEQSTA
Neither of you understood the very clearly worded question which stated that zoomfactor was not the setting they want. The OP wants two zoom factors. One for zooming in and another for zooming out.
Rob
Message 6 of 12
jonathanEQSTA
in reply to: RobDraw
To me it wasn't worded that clearly. I read it that @Anonymous wanted to be able to set different zoom rates for zooming in and out. Had the word "separate" been used, I would have understood it the same way you did.
I just assumed that @Anonymous understood that when you zoomed in a particular percentage factor, you would have to zoom out at a smaller percentage factor to return to exactly previous zoom. For 100% zoom in, you'd zoom out 50%. For zoom in 15%, you'd have to zoom out 13% - not quite 10%, but perhaps he didn't want to calculate the exact figure - hence it was presented as an example.
But if @Anonymous wants a separate setting each for the zoom in factor and for the zoom out factor, then I concede that AutoCAD does not provide them.
EDIT: I also thought it was possible that the OP may not have applied the ZOOMFACTOR setting properly. It can happen from time to time.
Message 7 of 12
pendean
>>>...different zoom in and out rates ...wheel forward and reverse movements...<<<
That's not a core feature of any AutoCAD version 2005, earlier, or later. It may have been a feature of your mouse driver or a 3rd party add-on.
Like you, I see nothing today in a websearch to activate that ability today.
Message 8 of 12
dieters
in reply to: pendean
Hi Andrew,
Yes, I remember this behavior. Many users found that they could scroll in and out to ratchet zooming in at a slower rate, which they considered to be a useful feature. Many more users submitted bug reports that zooming with the mouse wheel was broken, which is why we changed it.
But, as was previously suggested, you can change the ZOOMFACTOR system variable (perhaps even creating button macros to control fast and slow zooming with the mouse wheel). It’s also possible is to create a macro that uses ZOOM .95XP that zooms out by 5% each time to press a custom button or assigned key.
There are some additional zooming tips here that might give you some ideas:
AutoCAD 2020 Help: Have You Tried: Faster Zooming and Panning
https://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-10D3C9A9-22E8-4047-AED1-5E96C6C28866
Hope this helps,
Dieter
Dieter Schlaepfer
Principal Learning Experience Designer
San Rafael, California
Message 9 of 12
in reply to: dieters
Thank you everyone for your support and reply.
I do hope AutoCAD can/will include a feature for us users to change the settings for the mouse wheel.
Andrew.
Message 10 of 12
pendean
You can tell Autodedsk about your desires right here yourself if you want them to ever notice https://www.autodesk.com/company/contact-us/product-feedback
Message 11 of 12
dieters
You're most welcome, Andrew. And do consider submitting a feature request as Pendean suggested.
A couple of ideas that occur to me right away include:
- Introducing a new system variable that separates the zoom in rate from the zoom out rate.
- Enabling the Alt key to halve the zoom factor for finer control.
Maybe you have some even better ideas for efficient control of zooming.
Thanks and best wishes,
Dieter
Dieter Schlaepfer
Message 12 of 12
Youssef_Greige
It was also one of my favorite ways of cropping views back with autocad 2005 and earlier versions.
AutoCAD Inside the Factory
