I have a Elecom EX-G PRO trackball, and I've mapped the delete key to one of the extra buttons.
It works fine in every other program, but in Autocad, it just outputs a "." Anybody have any suggestions?
[ The subject line of this post has been edited for clarity by @pendean Original: Mapped mouse button giving wrong output]
Solved by SeedyNotions. Go to Solution.
Solved by paullimapa. Go to Solution.
It could be any number of things such as the latest Elecom mouse driver. Or you can try the same command on a different button.
Does mouse manufacturer have an online FAQ page? Is there an Elecom User's Group? If there is, post your question there.
Chicagolooper
Any difference if you were to toggle the num lock key on/off?
What does AutoCAD do if you just tap the DELETE button on your keyboard? are you sure this is not the problem
Delete does not work in AutoCAD (autodesk.com)
Or is your mouse driver doing something more unique?
the keyboard delete key works fine, it's just the mapped mouse button. All of the other mapped keys work fine as well. The mapped key works as a delete key in any other program, but in Autocad, it types a period instead of deleting things
Glad to have helped…cheers!!!
