AutoCAD Forum
Modules Program
24 REPLIES 24
Message 1 of 25
1297 Views, 24 Replies
Modules Program
All of a sudden I get the message that the Modules Program Director is missing from my AutoCAD 2013.  I tried a Reinstall but that did not fix the problem. Suggestions?
24 REPLIES 24
Message 21 of 25
in reply to: john.vellek
Hello John and thanks for your patience.  Yes, my tractor's steering problem is solved.  Any time tomorrow between 1300 and 1600 would work for me it that fits your schedule.  If you could call me @ <information removed by john.vellek> we could set up a link using either Team Viewer or Logmein123.com
Cheers
Bob
Message 22 of 25
john.vellek
Hi Bob, I do not have LogMeIn but I can use Teamviewer.  I removed the phone number from your last post to protect your security.  I will attempt to contact you at 11AM PST which is 14:00 your time I believe.
John Vellek
Message 23 of 25
Great - look forward to talking to you.
Thanks a bunch.
 Bob
Message 24 of 25
The only way to respond to this John is to say how profoundly I appreciate your help solving this problem.  Please tell your Supervisor that on a scale of 1 to 10 I would rate you as a 15.  She should take you out to lunch and pat you on the head. Good people are hard to find.
Cheers
Bob Price
Message 25 of 25
john.vellek
Hi @Anonymous,
It was a pleasure working with you remotely today even though it took us a while to connect.
Here are the steps we took to get your AutoCAD 2013 running the way you prefer.
1) We Rest Settings to Default. In this process we saved your old settings to a ZIP file that you should be able to find in your Documents folder.
2) We then located the one drawing file you typically opened by default (and set as read-only), saved a copy of it as a DWT template file.
3) We then set the QNEW variable to use that template whenever you open a new drawing file. Here is a video that shows more about QNEW and an article that details the command.
4) We also turned the UAC down so you will no longer be receiving a warning prompt when launching your AutoCAD. This feature can be found in your Windows Control Panel under the Users panel.
5) Once we launched AutoCAD 2013, we also adjusted the background colors and set the cursor size in the Display tab of Options.
6) We also set the 3D Workspace to current as that is where you typically work.
7) Lastly, we used APPLOAD to locate and load your gear lisp routine.
I hope that we caught all of the issues on your list of things to fix. Please return if there is something we did not address.
John Vellek
