AutoCAD Forum
Modelspace/Papers pace origin issue
1 REPLY 1
199 Views, 1 Reply
Actually myself and my friend are working on same project. Actually the issue is we didn't set the origin and worked out in modelspace because of which drawing are totally apart from each other while combining into one cad. All I did is moved the other part near to my dwgs and because of which viewport is totally changed when I tried to import layout. If I set origin for both dwgs inside model space at same base location but the viewport Origins ain't changing, is there any solution for fixing a issue like this please let me know asap.
1 REPLY 1
imadHabash
viewport's work as a window from paper space to view model elements . if you moved your model elements to another new location then you have to pick inside your VP and get those moved items again to your VP .
Imad Habash
Forma Design Contest
AutoCAD Beta
