modeling a mathematical shape
Message 1 of 10
Dear Community,
 I am really new in Autocad. I am using it just because I need to create a mathematical shape and fit it to a point cloud.
I need to plot the following offset paraboloid
(-6.4/18.6)*(u*cos(v))-(0.26/18.6)*(u*sin(v))-u^2/(4*(4.5))
with the following limit for variable u:[0:3.1] and v:[0:2*pi]
I tried to reproduce the model of another post: https://forums.autodesk.com/t5/autocad-forum/modeling-a-mathematical-shape/m-p/6880790#M163266
But when I uploaded I can not see anything.
Could you please give some advice?  Is there some place in Autocad where I just write my code without making a lisp "programm"?
regards,
Eugenia
Replies (9)
Message 2 of 10
john.vellek
Hi @Anonymous,
LISP and/or VBA might be the best way to get this done. I found this older thread that explores something similar to what you are trying to express.
John Vellek
Message 3 of 10
dbroad
If you just want to enter math formulas and generate a shape, then AutoCAD is not the best program to use.
Wolfram-Alpha will take your equation and generate what you want.  If you go-pro, then you might be able to export the data in a form that could be input to AutoCAD as a point cloud.  If you want to do it in AutoCAD, you need to write a program to translate the equation in to a surface.  AutoCAD used to include such a program, called fplot.lsp as part of its bonus tools.
I used to use MathCAD.  Others use Maple or Mathmatica.
Here is a clipped image from wolfram-alpha
Architect, Registered NC, VA, SC, & GA.
Message 4 of 10
SEANT61
The parametric span on V (0:2PI) suggests a revolution.  If the derived data is plotted as such, the resultant geometry is along this line.  I set everything symmetrical about the XZ plane, though the derived data indicates a slight rotation off of that plane.  Conceivably, the rotation is needed but, maybe even more conceivable, I've got an error in my spreadsheet setup.  Either way, this is what I ended up with:
May your cursor always snap to the location intended.
Message 5 of 10
vladimir_michl
You can get the model also directly in AutoCAD. Just load our 3DPLOT Lisp utility, enter your function definition in Lisp and call (3dplot).
See:
http://www.cadstudio.cz/en/apps/3dplot/
(defun MYFUNC (u v)
(list
 u
 v
 (- (* (/ -6.4 18.6) u (cos v)) (* (/ 0.26 18.6) u (sin v)) (/ (* u u)(* 4 4.5)))
(3dplot MYFUNC 0 3.1 0.1 0 6.28 0.1)
You will get this:
Vladimír Michl, www.cadstudio.cz  www.cadforum.cz
Message 6 of 10
Thanks, but the idea was not just building shapes. It was building a 3D object and matching with a point cloud.
Anyway I liked the tool you mentioned. I didn't know it.
Message 7 of 10
Thanks. I did it as you suggested but I couldn't  visualize it.
But maybe it is my AUTOCAD version...
Message 8 of 10
Many thanks! It worked fine for me. I could open it and the model was correct.
Now I've got my point cloud and model in the same drawing.
Regards
Message 9 of 10
ara_neresesian
hi
I think if you are using autocad LT (limited) it is not possible to load lsp file or 3d object
you have to run it in  autocad
Message 10 of 10
dbroad
Nice post @vladimir_michl ! Looks like a great tool. I'm going to mark this as a solution also since many AutoCAD users would use such a program rather than hand modelling the shape.
