Model Tab not displayed
paul.lefebvre5285H
Message 1 of 20
paul.lefebvre5285H
Using ProjectWise Integrated AutoCAD 2016.
Although Layout tabs show up, the model tab does not.  I have tried toggling on and off "display model and layout tabs" under Options, which does not help.
john.vellek has embedded your image(s) for clarity
Accepted solutions (4)
Replies (19)
Message 2 of 20
Patchy
Message 3 of 20
WarrenGeissler
Type ABOUT to see what SP level you are at. I saw this before and I think it was fixed with SP4. You see the little down arrows to the right of the tabs? (Left of your model button). Hit that.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 4 of 20
paul.lefebvre5285H
The window was un-maximized so that I could get a good screen shot.  Maximizing does not help.
Message 5 of 20
paul.lefebvre5285H
Warren -
I have SP1 installed.  Is there any way to know if SP4 solved this?
Yes, I can click on the double down arrows which lists all the layouts and models, and right clicking on any of the layout tabs also gives me an option to "activate model tab."  So those are two workarounds, but I would rather have the model tab back.
Message 6 of 20
WarrenGeissler
Not 100%. There were some "Status bar" fixes done, but the only thread posted here did not have a response. Worth a shot.
Warren Geissler
Message 7 of 20
BeKirra
Last week it happened with my mech 2016 when I was back in office from a period of leave.
What I did was clicking the area on left side of "Layout" tab. Then "Model" tab came back.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 8 of 20
paul.lefebvre5285H
Thanks for the suggestion BeKirra. I just tried this, and had no success.
Message 9 of 20
BeKirra
Did you try then link attached by Patchy?
Ensure "Display Layout and Model Tabs" is ticked in Options >> Display >> Layout elements.
HTH
X² + Y² = C²
Message 10 of 20
WarrenGeissler
Just talked to a client who was having the same issue - specifically they have Civil 3D and Projectwise. If you set STARTMODE to 0 you will see this behavior. Check that it is set to 1 on your system.
Warren Geissler
Message 11 of 20
chriscowgill7373
Sorry, late to the party.  what happens if you left click on the model tab in the double arrow pulldown?  Is there am option if you right click next to the layout tab to show tabs above the status bar?  you can use the system variable to switch TM <enter> 1 <enter> will switch to model.  0 will switch to the last used layout tab.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 12 of 20
BeKirra
Sorry, By re-reading your post #1, I did a search again and found nothing except system variable "LayoutTab".
X² + Y² = C²
Message 13 of 20
paul.lefebvre5285H
Suggestion:
"Just talked to a client who was having the same issue - specifically they have Civil 3D and Projectwise. If you set STARTMODE to 0 you will see this behavior. Check that it is set to 1 on your system."
Warren, thanks for the suggestion. STARTMODE is indeed set to 0, but the response when I try to change to 1 is "STARTMODE is read only". Any idea how to get around in order to try your suggestion?
Message 14 of 20
WarrenGeissler
How are you trying to change it? If you are just typing "STARTMODE" and it is replying that it READ-ONLY that is going to be an issue. It might be the ProjectWise that is goofing that up (although my client could change it at will).
Did you ever install the latest service pack? Again - I'm not 100% certain if that will fix the issue, but this is abnormal behavior.
Warren Geissler
Message 15 of 20
paul.lefebvre5285H
Hi All,
Thanks for the suggestions.  Just trying to button this up.  No "solution" was found, although there are some workarounds and untried suggestions.  The problem seems to be isolated to projectwise files.
Workarounds:
Using the double down arrows to the right always works.
Right clicking on any layout tab and selecting "activate model tab" always works.
If I open autocad and use file>open to browse to the file (rather than just double clicking a file in projectwise), model tab appears.
If I open a drawing by double clicking in projectwise, no model tab.  If I open a second drawing by same method, model tab appears in both drawings.
Untried suggestions:
Install latest service packs, potentially SP4.  I'm on SP1, but so are the rest of my colleagues - working for a big company, I can't go rogue and install a newer SP than everyone else.
Thanks everyone!
Message 16 of 20
EL_Shaw
I have just had this happen, I resolved it eventually by right clicking on the layout tab and creating a new layout tab from template.  I then deleted this tab as it wasn't needed and this made the Model tab reappear.
Message 17 of 20
linus.nyqvist
Community Visitor
Community Visitor
This worked for me! Not sure how I managed to untick it earlier.
Message 18 of 20
Left click the word "Layout" on the tab, hold and drag to the right and "model" should reappear. : )
Message 19 of 20
After reading thru this post, I found that left clicking on one of the layout tabs and attempting to move it by dragging will cause the model tab to return. Not sure why it was hiding as this was the first time the issue has shown itself.
Message 20 of 20
rjkohn112
Community Visitor
Community Visitor
This worked for me, click on the layout tab and drug it to the right, model tab reappeared
