AutoCAD 2018 Output pdf file size is 10x normal
I recently installed autocad 2018 and am having issues reducing the file size of outputted pdf's. The file size that is output is generally 10 times larger than what I expect and what previous versions of autocad put out.
What I have tried:
Reinstalling autocad
I have compared the output size and plotter settings from other versions of autocad using the same files several times as well as comparing settings between versions.
I can make some adjustments that amount to a small change in the file size (0-10%) but nothing significant to get close to the expected output size. (reducing vector/raster quality, excluding layer information, hyperlinks, bookmarks. Tried different font handling.)
I am looking to get a pdf from the file. Changing the settings from AutoCAD (General) to smallest file or dwg to pdf has not made much of a difference.
Let me know if you have any ideas. It seems like this is a default setting that needs to be changed as AutoCAD prints to pdf like this right off the bat. We have had this same issue with other computers trying to install 2018 as well in which we ultimately switched to 2016 instead.
