MODEL SPACE VIEWPORT
I have a query regarding autocad viewport in the Model Space.
Suppose when working in Model space i split the space into 4 viewports .
All viewports show same elements in each view.
My Question is
if there is plan ,front elevation,section and specification in the dwg.(all viewports show all -plan ,front elevation and section and specification)
1) now by zoom/PAN options i set top left viewport showing just front elevation
2) the bottom left i set to plan view
3) then in top right i keep the section
4) and at bottom right i keep specification
now all set.I WANT TO COPY THE VIEW AT top left IN THE bottom right ,
how can i do that in a single command
(i can use the zoom in & zoom out,etc zoom options) But is there some command to copy the view from 1st divided vieports to some
another viewport of the 4 viewport i spilted.
It is available in microstation (that one window view can be copied on to another window view)if have ever got to use microstation,it is a quite useful command(COPY VIEW)
I wonder is there any such command in Autocad,if not there why havent there programmers made some command of same sort.
Solution on the above mentioned question is eagerly awaited,please be helpful to share the solution.
Thanks & Regards
