AUTOCAD 2017 NOT WORKING/ERRORS
Message 1 of 8
Hi, I'm currently using Autocad 2017 (student version) on ASUS laptop with Windows 10 (64-bits) and intel core i5 (7th generation) with a NVIDIA GEFORCE 930 Mx graphics. My laptop's ram is 12.0 GB.
I am facing a hell lot of issues with my Autodesk software (AutoCad 2017 and 3Ds Max 2017) recently and it is making me mad. My AutoCad is not functioning and the startup view port corrupted everytime I launched the software. And after a few actions the software freeze and stopped working.
the start up viewthe start up viewshowing fatal error: trouble abortingshowing fatal error: trouble aborting
I hope someone can help me out, thanks in advance!
Replies (7)
Message 2 of 8
imadHabash
i suggest to install the latest service pack. then let's see if any changes. >> Click <<
Imad Habash
Message 3 of 8
Hi, thanks for replying.
I tried your suggestion but it didn't work. There's also a tiny window popped out saying that my graphic card denied the access or something...
Message 4 of 8
imadHabash
>> ..... that my graphic card denied the access or something <<
then try to update your certified hardware database to the latest version. >> Click <<
all the best
Imad Habash
Message 5 of 8
pendean
Community Legend
Community Legend
Have you turned off hardware acceleration yet? Worth trying. You can do it before AutoCAD comes up on screen like this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Starti...
See if this is also the problem https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-products-not-wo...
Message 6 of 8
Thanks, your first suggestion works, though there are some minor lagging situation and some difference... well, it works fine but I hope this is normal after I turned off the hardware? When I select an object it turns into dotted line (previously it was cyan solid line) or it is actually customizable?
But my start up page is still corrupted and I am wondering the cause of it... seeing this every time I launch the software makes me super insecure...
Thank you so much for your time and suggestions! I really appreciate it
Message 7 of 8
Hi, thanks for your kind reply, unfortunately my software is by default so it will automatically check for updates but I never received any...
Message 8 of 8
dgorsman
Turning off hardware acceleration is more of a diagnostic tool than a solution.  If it tends to fix things, it's a good sign there's problems with the graphics system.  Hopefully you just need to update the driver for your graphics card.
The GTX 930 is a bit of an older card, so it may not perform well with newer software.  You especially might find some problems with that version of 3DSMAX (check the AREA boards for that program if you haven't done so already).
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
