AutoCAD Forum
close problem
3 REPLIES 3
ugur.bakir
206 Views, 3 Replies
close problem
İ use Autocad 2014 on Windows 10. My problem's; when i click any button on the ribbon menu, Autocad freezes and closes.
3 REPLIES 3
ennujozlagam
in reply to: ugur.bakir
@ugur.bakir hello, try to install latest updates from autodesk and see if helps., thanks
Or you can refer to this LINK.
Vinayv4v
Refer this article:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
Further testing of Autodesk 2013–2015 products is required to determine compatibility with Windows 10 and should be considered unsupported on Windows 10 unless explicitly stated otherwise in the details that follow or in the system requirements for that product and version. Please note the following product-specific details:
  • 2014 and older versions of AutoCAD and AutoCAD-based verticals will not be supported on Windows 10.
  • The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
  • Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
  • DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
Cheers,
Vinay Vijayakumaran
pendean
Your version of AutoCAD2014 is not supported in Win10 as explained here http://autode.sk/1IY4C2X
For most users these free tips help a lot http://www.howtogeek.com/228689/how-to-make-old-programs-work-on-windows-10/
For others still they purchase a fix from these folks http://www.longbowsoftware.com
As far as Autodesk is concerned, you will need to subscribe to a newer version of AutoCAD.
Hope these help.
Forma Design Contest
