Viewport Controls [-]
Select [-] for options to maximize the viewport, changing the viewport configuration, or controlling the display of navigation tools.
View Controls [Top]
Select [Top] to choose between standard and custom views. Quick access to manipulate your view of an Isometric or 3D drawing.
Visual Style Controls [2D Wire Frame]
Select [2D Wireframe] to choose one of several visual styles. Most of the other visual styles are used for 3D visualization. Quick access from a 2D view to see your 3D drawings in different visual styles.
* Note when you see the Blue Box with a Check mark in it this represents the active or current features. When another option is needed, select that feature with the mouse and this will make that the current style option.
* Note also that the options in the brackets [ ] change to the new option that is selected.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
