Hy everyone
How can i put fast , 25pieces - A4 format, from model space to 25 different layout, and not one by one, using old procedure : pagesetup, copy to end, zoom object in viewport......
@zsolt ,
Take a look in the AutoCAD App Store:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
@follert wrote:Thanks, but a "free" solution 😉 ? an autocad command 🤔 ?
Not really fast if you only want to use core commands, speed required pre-planning in AutoCAD, and it's still one by one.
Or you can install one of the free add-ons from the Autodesk App store like the rely you already received: they might just be faster
Core commands, no fear of ad-ons, one by one is the only way:
CHSPACE command if you have layouts ready with scaled but empty viewports.
or MVIEW command is each of your modelspace content has a scaled an named VIEW already defined, leaving the content in modelpace.
or CUTCLIP and PASTECLIP commands in combination, but your layouts need to be pre-defined and ready.
There are LISP routine out there too, but you'll have to test and possible tweak to meet your exact needs.
How would you like to proceed @follert ?
