AutoCAD Forum
mleader, block , layers problem
2 REPLIES 2
346 Views, 2 Replies
Hello
one of my customers asked me the following problem
a mleader style use a per user block contains
this block contains
  graphical objects (polyline or circle) in the layer C_C
  texts in the layer C_A1
  attributes, somme of them are in the C_A1 layer, the others are in the C_AR layer
the layers have differents colors
after inserting the mleader, all the attributes have the same aspect (same color) and do no respect their layers states
If I freeze the C_A1 layer, the texts disapper, the attributes not
If I freeze the C_AR layer, all the attributes disappears
It appair, all the attributes use the configuration of the last of them , (changing the attributes order change the visible results)
How can I have a logical working (respecting the proper layer states, and the rights colors) ?
attached, you can find a sample
regards
Luc
2 REPLIES 2
john.vellek
Hi FRFR1586,
Interesting conundrum!  It appears that the BYLAYER settings do get ignored when it gets attached to the multileader. I played with one of the attributes and changed its color to 82 (to match the current color of the layer it is on). It seems to retain the color setting!
So I guess the answer is yes - it doesn't work quite as expected. Perhaps this indicates a Leader and a block is more appropriate in this situation.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
in reply to: john.vellek
Hi John,
the problem with the colors is one part of the complete problem
the badly respect of the layers state (then freezing) is more troublesome
regards
Luc
Forma Design Contest
AutoCAD Beta
