Mleader background mask buffer doesn't match frame around text
C3D_TomR
Advisor Advisor
Message 1 of 11
C3D_TomR
The new text frame for mtext uses the background mask offset so that if background mask is enabled, the text frame matches that masking. That isn't the case for mleaders and has been an issue since mleaders first appeared in AutoCAD. Please take a look at this issue and see if if can be fixed.
Thank you.
--Tom
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Replies (10)
Message 2 of 11
Pothman
Thanks for the post. Can you attach a sample drawing showing this issue?
Dave Pothier
Message 3 of 11
C3D_TomR
I've attached a sample mleader style created in an OOTB Civil 3D template. Here's what I see in version 2015.
MLeader Text Frame Background Mask Issue
Tom Richardson
Twitter | LinkedIn
Message 4 of 11
jmayo-EE
I have the same issue. The mask and text frame should match but they don't if you begin to grip edit the mleader width.
If this gets to development it would be real nice to have full control of the mask and frame from the properties dialog and with a right click function.
Presently you can turn the mask on in the props dialog but there is not control for the mask color.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
Message 5 of 11
C3D_TomR
I agree with @jmayo-EE regarding the need to access background mask properties such as offset and color. This could be accomplished by adding a button that opens the current background mask dialog. Having this setting in the mleader style would save a lot of extra clicks after placing the mleader. Thanks for adding that comment, @jmayo-EE.
--Tom
Tom Richardson
Twitter | LinkedIn
Message 6 of 11
Pothman
I can see this behavior in your drawing but so far I have not been able to duplicate this issue from scratch. Could you possibly create a Screencast showing how you did this from scratch?
www.autodesk.com/screencast
Dave Pothier
Message 7 of 11
C3D_TomR
The video is recorded and uploaded but may not be done processing yet on the Screencast page. Here's a link.
https://screencast.autodesk.com/main/details/56a9c62e-547b-478d-ba7e-22dd2755e155
Tom Richardson
Twitter | LinkedIn
Message 8 of 11
Brooms-ca
Observer
Observer
I found this thread because I have the same problem in AutoCAD 2013.
After seeing you had the prblem in a 2015 vertical, I tested this behaviour on and install of AutoCAD 2016. It appears to have been fixed in 2016.
Message 9 of 11
Brooms-ca
Observer
Observer
Okay Tom, here is a workaround:
  1. Remove the mask from the Frame in Properties.
  2. Edit the MText and select Background Mask from the Text Editor Ribbon.
  3. Change the Border offset factor to suit the Frame (iterative process).
For example, I had a Frame Offset of 1.5 and I had to edit the MText Border offset factor to 1.59 to work with the Frame.
Brad
Message 10 of 11
MWM_TomR
@Pothman @jmayo-EE @Brooms-ca
The creative solution we found for this issue is to set the Landing Gap in the mleader style to 0.05. The OOTB default is 0.09. Once we changed this value in the mleader style the background mask matches the text frame extents.
--Tom
Message 11 of 11
KDAddison
I never use mleaders because this trash.  They're not worth the frustration.
