Text explode
Text explode
TuncayBAKKAL01
Advisor Advisor
Message 1 of 18
Text explode
TuncayBAKKAL01
I need exploded text. I use explode command on mtext object.
Message is 1 was not able to be exploded.
Thank you for support.
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Replies (17)
Message 2 of 18
tmccar
If you have Express Tools, you can do this with the "_TXTEXP" command.
Message 3 of 18
Albert_Rius
Hi TuncayBAKKAL,
Welcome to the AutoCAD answer day!
I understand that you can't explode Mtext elements to text, right?
Can you post a sample file to check what can be wrong? by default the explode command should convert all mtext lines in text.
Thanks for sharing.
Albert Rius
Technical Support
Autodesk, Inc.
Message 4 of 18
TuncayBAKKAL01
Explode command not working on mtext and text for AutoCAD 2016.
txtexp command working.
file is attached.
TuncayBAKKAL
Message 5 of 18
Albert_Rius
The Explode command converts MTEXT to TEXT, it was not defined to convert text to a group of lines/arcs that defines the character boundary, for this you need to use the TXTEXP as mentioned.
____________________________________________________________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
Message 6 of 18
TuncayBAKKAL01
TuncayBAKKAL
Message 7 of 18
It doesn't look like this command comes with AutoCad 2015 LT for MAC
I was familar with txtexp on my previous system and now the command doesn't exist?
Is there a work around to convert mtext to lines and arcs?
Message 9 of 18
I don't have access to the wmfout; wmfin commands.
Message 10 of 18
Patchy
Ask the Mac forum to see if they know how.
Lt using Windows has it.
Message 11 of 18
I definitly don't have it.
Below is a screen shot of available commands for the version of AUTOCAD i'm running.
I definitly don't have the txtexp either..which is what i was used to.
Message 12 of 18
Patchy
Mac doesn't have Express Tools
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
So TXTEXP doesn't work, time to use Windows platform if you really need more commands.
Message 13 of 18
jackshield
I thought all the "LT" products were void of express tools?
Message 14 of 18
Patchy
Lt Both Mac and Windows don't have ET
I doubt that he said he uses that command (TXEXP) before is true.
But WMFOUT to explode text can be used with LT for Windows.
Message 15 of 18
I used it before on a PC older version of windows.
Message 16 of 18
If you want the Roman Simplex font, one alternative is to generate the text online with this tool:
http://wildsparx.com/textlines
This gives you a dxf which you can INSERT.
Message 17 of 18
gustavo.medinaWQGRY
Community Visitor
Community Visitor
I found something... (I neither have the Express tools)
I plotted a MTEXT as .PDF, then that .PDF convert to .DWG
Capooomm!!!
#explodetext
Message 18 of 18
rimalu
Community Visitor
Community Visitor
"There is a small trick that will do the job: set the MIRRTEXT system variable to 1, mirror the labels by a vertical axis and do the WMFOUT --> WMFIN procedure again on the mirrored copies. Since such labels were not supported in WMF format, AutoCAD will export them as curves. For sure, after import, will need to mirror them back."
Solution proposed by MSasu - thank you.
It works perfectly and what's more it doesnt't require any additonal LISP procedures.
#explode MTEXT
#explodemtext
