AutoCAD Forum
Mleader Autolisp
4 REPLIES 4
joseZ9KZ7
354 Views, 4 Replies
Mleader Autolisp
Hi all,
I'm starting with autolisp. My second "project" is a multileader that shows secuential text (hopefully TR1, TR2, TR3 ... and it would be awesome if I can figure out that the same autolips allows me to do afterwards PL1, PL2 PL3...)
After a couple of hours I just got to the point that the file just show me the text that I set as a variable n.
Below the code
(defun c:activateleader ()
(while
(setq n 5)
(command "_mleader" "o" "m" "2" "x" pause pause n)
(SETQ n (+ n 1))
Could you please tell me what am I missing in the code?
Thank you very much in advance.
Tags (1)
4 REPLIES 4
tramber
in reply to: joseZ9KZ7
(defun activateleader ()
  (setq n 0)
  (while
    (< n 5)
    (command "_mleader" "_o" "_m" "2" "_x" pause pause(strcat "prefix_" (itoa n)))
    (SETQ n (+ n 1))
(defun c:al()(activateleader))
ВeekeeCZ
Or like this.
(defun activateleader (prefix n / i)
  (command "_mleader" "_o" "_m" "2" "_x") (command) ; setting
  (setq i 0)
  (repeat n
    (command "_mleader" pause pause (strcat prefix (itoa (setq i (1+ i))))))
  (princ)
(defun c:mltr5 () (activateleader "TR" 5))
(defun c:mltr5 () (activateleader "PL" 5))
Or your code fixed:
(defun c:activateleader_0 (/ n)
  (setq n 1)
  (while (<= n 5)  ; while some condition. You can theoreticaly have while (= n 5) but not re-set 5 every run. But if you have fixed number (you already know that is 5 times, its better 'repeat')
    (SETQ n (+ n 1))
  (princ) ;silent exit
joseZ9KZ7
in reply to: ВeekeeCZ
Thank you very much Beekee and Tramber. I really appreciate all your help.
Unfortunately the only code that nearly get to what I wanted was the last one by Beekee.
  (setq n 1)
    (SETQ n (+ n 1))
I'm attaching the file if it helps.
I'm going to keep working on the code to reach my objectives previously described. In the mean time, if you could try to help me to find the solution would be awesome.
Anyway, again thank you both. You are advise help me a lot.
ВeekeeCZ
I must admit I never this kind of setting, so I didn't know it's just for current mleader.
Why don't you adjust the style to allow just 2 points?
Anyway, the following code should work as expected.
  (setq i 0)
  (repeat n
    (command "_mleader" "_o" "_m" 2 "_x" pause pause (strcat prefix (itoa (setq i (1+ i))))))
  (princ)
Forma Design Contest
AutoCAD Beta
