Mirroring blocks with attributes and text
Message 1 of 12
I have a block with an attribute embedded and text and I'm trying to create it so that when I mirror it, the text does not flip and it also remains justified bottom right like when it is not mirrored. Essentially, I want the whole block to look the same when I mirror it in the Y-axis. (This is for mirrored floor plans)
I've attached the dwg file. Any suggestions would be much appreciated! Thank you!
Replies (11)
Message 2 of 12
MIRRTEXT=1
Message 3 of 12
Hey thanks for your reply, but Mirrtext=1 doesn't do the trick. I attached the file in my previous post so you can open it and investigate further.
Message 4 of 12
imadHabash
I suggest to read this good AKN article.the story is more than Mirrtext system variable especially when you treat with attributes.
Imad Habash
Message 5 of 12
Edwin.Saez
HERE I AM ATTACHED THE MODIFIED BLOCK.
Change the text by an attribute.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Message 6 of 12
john.vellek
Hi @Anonymous,
Your block is a dynamic one with visibility states but I only see one state.  Can you give me some background on what you are trying to create?
As others have pointed out, an attribute with a constant value checked when creating it will behave this way. Are you trying to provide a light switch with different heights? Is there a reason each height can't be a simple piece of text with each assigned to it's own visibility state? Or perhaps you are trying to do something else here.
I see that you have escalated this issue three times. Is this intentional? You don't actually need to start a post in order to do this so I am a bit confused but I am here to help if you would like to work through this issue in this thread.
John Vellek
Message 7 of 12
Hey thanks for the reply. Perhaps I was a little unclear with explaining. Essentially I am working on a townhouse, with mirrored floor plans and want to create a block for a light switch with text to indicate heights justified on the bottom right. When I mirror the floor plan, the text justifies to the left of the switch symbol, whereas I want it to be on the right, so the block looks exactly the same when it's in its mirrored state as its regular state.
Sorry about escalating the issue, that was an accident.
Thanks in advance!
Message 8 of 12
john.vellek
HI @Anonymous,
Text in a block is going to mirror. The way to avoid this is to make the text an Attribute.  If you want to have "fixed" values to choose from you might consider using multiple attributes or perhaps a Lookup.
One option to discourage users from editing the attributes is to make them Preset, and locked and then to assign each one to its own visibility state.
John Vellek
Message 9 of 12
I dunno man, while they don't mirror right in a block, text and mtext "flip" just fine here with the right MIRRTEXT setting.
Message 10 of 12
lanceX2G2C
This just saved me. Thank you!
Message 11 of 12
fmtampos
Community Visitor
Community Visitor
Good sample file but how to make it, was not explain. 🙂
Message 12 of 12
vinodkl
Hello @fmtampos
Kindly share your sample drawing, and I will guide you on how to achieve the desired outcome.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
