AutoCAD Forum
Mirror Text
17 REPLIES 17
Message 1 of 18
36365 Views, 17 Replies
Mirror Text
Hello Dears,
When I use the mirror command it rotates my text, what is the system variable I need to change, I appreciate any help.
17 REPLIES 17
Message 2 of 18
Kent1Cooper
If by "rotates" you mean it makes it come out backwards, it's the MIRRTEXT System Variable that is set to 1 -- you want to set it to 0 [read about it in Help].
Kent Cooper, AIA
Message 3 of 18
in reply to: Kent1Cooper
Thank you for your reply kent1cooper,
what is happening is when I try to mirror the text it rotates by 180  instead, I attached you an image.
Message 4 of 18
Message 5 of 18
john.vellek
Hi @Anonymous,
I have not seen this before. Does it matter what type of font is used in the style? Is it possible to attach a sample file that displays this behavior?
Is this perhaps related to your current UCS at the time when you mirror?
John Vellek
Message 6 of 18
Vinayv4v
Does this problem occur in all your drawings or only in a particular drawing. Which version of Autocad are you using?
Have you tried Audit, Purge. Close & restart autocad and check whether the problem is still existing.
Check this thread with similar issue (no solution found)
https://forums.autodesk.com/t5/autocad-forum/mirrored-text-rotated-180-degrees/td-p/1273907
Please upload a sample file to find a feasible solution.
Cheers,
Vinay Vijayakumaran
Message 7 of 18
ara_neresesian
Hi solarch,
I have not seen this kind off mirror
its like 2 time mirrored first by Y axis  and second  X axis.
its is possible with rotate/copy.
Please send you file to forum
Please select the Accept as Solution button if my post solves your issue or answers your question
Message 8 of 18
TheCADnoob
Is the text annotative and is it possibly in a block or some other insert?
CADnoob
Message 9 of 18
pendean
is this a block within a block?
Otherwise it's time you posted a DWG file with the problem, let's all touch what you are touching in that file.
Message 10 of 18
in reply to: john.vellek
Yes I think it is related to UCS if it is world UCS it works right, but if the UCS is not world , it rotates the text when I mirror it.
Message 11 of 18
john.vellek
Hi @Anonymous,
Is it possible to attach a sample file that shows this behavior?
Does the mirror work correctly if your current UCS matches the object when you do the mirror?
John Vellek
Message 12 of 18
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post back with any new information if the issue continues.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 13 of 18
JoshuamRivera
text inside a block, when mirrored the text is incorrect, no readable. Mirrtext not working, it works with attdef text, but when that attdef text gets added to inside the block it disappears.
Message 14 of 18
pendean
in reply to: JoshuamRivera
Correct, TEXT in blocks has worked like that in this program is by design. Now you know to never use just TEXT in blocks if you wish to have the ability to mirror a block with letters/words in it.
Message 15 of 18
JoshuamRivera
in reply to: pendean
If I draw simple lines to create a wall, a simple line to represent a wood header over an opening. To group this as a block to be copy /pasted/ mirrored at multiple locations. That is the end game.
But to that I need text along with the wood header.
regular text with the mirrored block does not work, not readable.
If I create ATTDEF (which mirror text works with) and that one text line I add objects to the block the text then disappears.
To bypass this  I place the ATTDEF text to each window opening location, then I select all ATTDEF plus wall lines, wood header lines and all at once create the unit block , that works. But if any future edits need to be made , example moving text a little, or updated text entry , or copy pasting to a new window, once you click save changes it does not reflect new updates, new items disappear. But when you click edit block the items reappear.
I just don't get it, years ago this all worked just fine with other versions.
This issue here destroys our production output and processes.
Message 16 of 18
pendean
@JoshuamRivera I have no idea what you might have used or done years ago, so I cannot help you decipher what's different today. Sorry.
For your current issue, you'll probably need to share a DWG file with the edit-now-stops-working problem for others to examine.
Message 17 of 18
JoshuamRivera
I created this small work file for your use with detailed instructions. @pendean
Message 18 of 18
pendean
Looks like you are ready to jump into creating and using Flip parameters in Dynamic (not regular) Blocks. Perhaps that is what you all used to do and those got lost somewhere along the way.
There is a dedicated forum on the topic, here is the link https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Repost there and combine your last to replies here into one, don't forget to add your DWG file.
And lots of online tutorials if you wish to dive in deeper
https://designerhacks.com/create-mirrorable-dynamic-blocks-autocad/
https://betweencadclasses.wordpress.com/2020/09/20/autocad-dynamic-blocks-part-2-alignment-grip/
https://betweencadclasses.wordpress.com/2020/09/21/autocad-dynamic-blocks-part-3-flip-mirror/
AutoCAD Inside the Factory
