AutoCAD Forum
Mirror rendering
5 REPLIES 5
964 Views, 5 Replies
Mirror rendering
Hi, i am a newbie in autocad 2013, i am now trying to draw a 3d mirror to be placed on a table , but stuck with rendering the mirror, so it would be great if i get some instruction on how to render a mirror object stepwise . please help. thank you.
Tags (1)
5 REPLIES 5
Sofia.Xanthopoulou
Hi @Anonymous,
and welcome to the community Smiley Happy
How about this video, showing how to render objects.
Well, I hope I understood correctly that you want to render an object, in this case a mirror, right?
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hi @Anonymous,
if you don't give any feedback nobody will know if I gave you the correct answer or totally misunderstood your question.
Please give all readers the opportunity to benefit from your experience by continuing this conversation or accepting a solution.
Thank you
Tags (1)
in reply to: Sofia.Xanthopoulou
HI THANK U FOR YOUR SUPPORT, BUT THAT VIDEO DID NOT HELP ME IN MIRROR RENDERING. I NEED VIDEO OR ANY INSTRUCTION ONLY RELATED TO MIRROR RENDERING.THANK YOU
@Sofia.Xanthopoulou wrote:
Hi @Anonymous,
Thank you
Hi @Anonymous,
Thank you
NOT HELPED ME IN MIRROR RENDERING. I NEED THE VIDEO OR ANY INSTRUCTION ONLY FOR MIRROR RENDERING. THANK YOU.
Alfred.NESWADBA
Assign your mirror-object a material that has mirror options set and render.
It's hard to create a video for your situation while we don't know where you exactly have the issue.
Upload your drawing file as well as a rendered image from that and describe what happens on your system, which object should mirror and what you have tried.
That's a screenshot to show the principle setting for a global material to make it mirroring.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
THANK YOU VERY MUCH. THIS IS HELPFUL.
AutoCAD Inside the Factory
