Hi every body,
I want your help to (flip) change the mtext position as per the attached file for few objects one time.
I tried to use TEXTFLIP lisp but in not working as i want.
Attached the cad file and the TEXTFLIP lisp
Hi every body,
@Anonymous hi,
the request result is not a mirror/flip it's a simple copy. to preserve an mtext in a reading state set MIRRTEXT to 0.
moshe
@Anonymous hi,
moshe
Dear Moshe,
I tried your suggestion but it is not working
Dear Moshe,
Is the "wrapping" from the first line in the Mtext content to the second line done by way of a hard return [Enter], or is it the result of the defined width of the Mtext "box"?
The "halves" can be reversed, but how that is done depends on the answer to the above.
Attached the lisp which used to create coordinates.
