Middle button as a Snap Menu
Message 1 of 11
There has been lots on information on how to turn the middle scroll wheel as pan. I use the middle button for a snap menu instead. I despise the middle button as a pan option. Anyhow, Mbuttonpan is set to 0, I have exhausted all efforts to try to get my snap menus back as my middle button. How do I get my middle button snap menu back. I have been using the snap button menu for the last 15 years, so learning to use the pan function does not work for me.
Replies (10)
Message 2 of 11
Patchy
Can't go back a decade ago, hold the shift key or Ctrl key down and middle button that's all you get.
Message 3 of 11
I had a computer upgrade in the last couple of weeks, The CUI file has been changed. I am still running the same version, just on a different machine. It worked 3 weeks ago it should still work. While I appreciate the sarcasm, the problem remains in the CUI changes. Shift-click does nothing either.
Message 4 of 11
Patchy
There is a setting called RESET to Default, have you tried to use that option?
Message 5 of 11
Yes I have, Right now if I push the middle button, the Aperture & Cross hair go off when I hold the button down, they come back when I depress it.
Message 6 of 11
RobDraw
When I change MButtonPan to 0, I get the shortcut menu. Tested in MEP 2020 and LT 2020. Maybe it's a mouse setting.
BTW, pushing the button and depressing it are the same thing.
Rob
Message 7 of 11
The mbuttonpan is set to 0, that's whats so confusing about it. It's not a mouse setting either, tried that one.
Message 8 of 11
RobDraw
The behavior you want is default when MButtonPan is turned off. Since you reset to default settings, I am leaning towards your new hardware.
Are you running any vertical products?
Do you get any menus when you right click?
Rob
Message 9 of 11
I will be re installing the version and will remake all my custom settings hoping it will reset back to the default settings in Cad.
Message 10 of 11
RobDraw
I wouldn't go all nuclear, yet, but that's up to you.
I did ask a couple questions that might reveal what the problem is. Would you care to answer them?
Rob
Message 11 of 11
I have reinstalled 2020 and it works fine now, when it was initially installed the settings were migrated over from 2017. The middle button now has the snap menu.
