AutoCAD Forum
meters drawing changing into feet scale value
5 REPLIES 5
1387 Views, 5 Replies
From meters drawing changing into feet what is the value?
5 REPLIES 5
Patchy
Autocad will do that for you by using the command:
-DWGUNITS
and follow the prompts
in reply to: Patchy
please give the ans ..................
sorry sorry.............what am asking the DWG meeters drawing file copying and pasting in feets DWG file  ok then how to scale into feets what we copy meeters flie????
Alfred.NESWADBA
if you have set the UNITS correct in both drawings then AutoCAD should do the scale for you.
Otherwise us Google .. there a so many calculators available >>>click<<< 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
