I have created some dynamic block with attributes. How can add these blocks into menu line as new pull down menu please.
Thanks & regards
Wanni
I think for such a case you need TOOL PALETTES . for more help i'm sure that you will get it from ( http://www.cad-notes.com/creating-your-own-autocad-palette/)
Good Luck..
Imad Habash
I know you said pull-down menu, but just as an FYI: In 2015 and later, blocks in the drawing automatically show up in the Insert drop-down, in the Block panel of the Insert tab of the Ribbon. More information.
