hi guys,
i'm working with point clouds. is there any physical memory limitation working with autocad. because i had 32gb ram but didnt see over 4 gb for usage by autocad. my computer's os is win7 x64.
http://images.autodesk.com/adsk/files/Autodesk_AutoCAD_Reality_Capture_Memory_Leak_Hotfix_Readme.pdf
Seems to be the opposite effect to what you're having. Anyway, have you tried to install the latest hotfixes?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21475673&linkID=9240618
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Are you using the built-in point cloud tools, ReCap, or a third-party tool like CloudWorks or Kubit?
Hello
I don't the limit in memory used by the 64 bits "ACAD.exe" task !
On 8 Gb PC with Win Seven Pro 64 and ACAD/MAP 201X 64bits, I have already used up to 6 Gb ...
I will test soon very large DWGs (NOT Point Cloud) with a 32 Gb PC (HP Z1 Workstation) !
Of course I will share my Infos ...
Bye, Pat
Patrice BRAUD
