AutoCAD Forum
Measurementsin 3D models
3 REPLIES 3
245 Views, 3 Replies
Hi, I'm new in this forum so I hope someone can help me.
I'm using a software of processing images, pix4d, so I can generate a 3D texture mesh, the formats that I get from this software are DXF,FBX,SHP,OBJ, PLY. In the end, I want import one of this formats to autocad desktop and take measures of width, height, volume, distance, etc in a 3D model that I get, so, is there a way for do that?
I hope not to be confuse, and I will appreciate the help.
Thank you.
3 REPLIES 3
dennis
The one is recognized by AutoCAD would be the DXF.  The SHP is also a file type AutoCAD uses for Shape Files, but I suspect that is not going to be the same format.  You can open a DXF easy enough by just changing the Files of Type of the Open dialog.  Once in AutoCAD, you should have snap-able geometry.  To get the area you will most likely need to draw a volume object like a Cube in 3D to then determine the area.
JDMather
@Anonymous wrote:
...DXF,FBX,SHP,OBJ, PLY. .... and take measures of width, height, volume, distance, etc in a 3D model ....
Autodesk Inventor and Fusion 360 can use the OBJ and I think the PLY (haven't checked that one).
Make that Autodesk Meshmixer for the PLY.
I suspect the real trick will be getting a solid body for Volume measurement.
If you can zip and attach your exports here - I can give it a go.
Given that most of these formats are meshes rather than solids, if the dxf isn't a solid you might have to go beyond AutoCAD to convert and then back to AutoCAD.
Alfred.NESWADBA
with AutoCAD you can
  • use command _OPEN or command _INSERT to load the DXF (open it or insert it into the current drawing)
  • use command _IMPORT to insert the FBX file as well
If you want to do tests with the OBJ file you can use the >>>Autodesk FBX Converter<<< which can convert that file and some other formats used in the 3D-visualization branche.
Be careful, images do not have sizes, converted meshes from images has to be first scaled  to a reference distance before you can do such measurements.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
