Measure Distance Between 2 Points
PhilvK
Advisor Advisor
Message 1 of 15
PhilvK
I just upgraded from Acad 2018 to 2023. How do you measure the distance between 2 points in v2023? The measure tool under the draw panel doesn't allow me to pick 2 points as in previous versions.
Accepted solutions (4)
Replies (14)
Message 2 of 15
whitney_jeff
Try DI or DIST
Measure is for placing points or blocks at specified spacing along an object
Message 3 of 15
user181
Try the measure on the Utilities panel on the right of the ribbon. Click the down arrow and there are several options
Message 4 of 15
imadHabash
  • MEASURE command .. Creates point objects or blocks at measured intervals along the length or perimeter of an object. >> Click <<
  • MEASUREGEOM command .. Measures the distance, radius, angle, area, and volume of selected objects, a sequence of points, or dynamically. >> Click <<
  • DIST command .. Measures the distance and angle between two points. >> Click <<
Imad Habash
Message 5 of 15
PhilvK
user181 - I seemed to have lost my Utilities menu
Message 6 of 15
PhilvK
Jeff - Thank you..DI works
Message 7 of 15
PhilvK
Jeff - Thank you...DI works
Message 8 of 15
pendean
Community Legend
Community Legend
Right click in an empty spot on the ribbon, then find and turn on that missing panel
Message 9 of 15
whitney_jeff
Mark as accepted please
Message 10 of 15
PhilvK
I tried the right-clicking but see 'Utilities' or anything like it.
Message 11 of 15
PhilvK
Oops
Message 12 of 15
PhilvK
I DON'T see Utilities
Message 13 of 15
user181
Utilities is in the Drafting and Annotation Workspace. Maybe you are currently using a different workspace and would need to switch to see it.  From your image looks like you are in the 3D modeling workspace.
Message 14 of 15
pendean
Community Legend
Community Legend
Message 15 of 15
PhilvK
Bingo! That did it. Thanks.
