Measure Distance Between 2 Points
PhilvK
PhilvK
I just upgraded from Acad 2018 to 2023. How do you measure the distance between 2 points in v2023? The measure tool under the draw panel doesn't allow me to pick 2 points as in previous versions.
0 Me gusta
Responder
Soluciones aceptadas (4)
3.045 Vistas
14 Respuestas
Respuestas (14)
whitney_jeff
Solución aceptada
Try DI or DIST
Measure is for placing points or blocks at specified spacing along an object
0 Me gusta
user181
Try the measure on the Utilities panel on the right of the ribbon. Click the down arrow and there are several options
0 Me gusta
imadHabash
  • MEASURE command .. Creates point objects or blocks at measured intervals along the length or perimeter of an object. >> Click <<
  • MEASUREGEOM command .. Measures the distance, radius, angle, area, and volume of selected objects, a sequence of points, or dynamically. >> Click <<
  • DIST command .. Measures the distance and angle between two points. >> Click <<
Imad Habash
0 Me gusta
PhilvK
user181 - I seemed to have lost my Utilities menu
0 Me gusta
PhilvK
Jeff - Thank you..DI works
0 Me gusta
PhilvK
Solución aceptada
Jeff - Thank you...DI works
0 Me gusta
pendean
Community Legend
Community Legend
Right click in an empty spot on the ribbon, then find and turn on that missing panel
0 Me gusta
whitney_jeff
Mark as accepted please
0 Me gusta
PhilvK
I tried the right-clicking but see 'Utilities' or anything like it.
0 Me gusta
PhilvK
Oops
0 Me gusta
PhilvK
I DON'T see Utilities
0 Me gusta
user181
Solución aceptada
Utilities is in the Drafting and Annotation Workspace. Maybe you are currently using a different workspace and would need to switch to see it.  From your image looks like you are in the 3D modeling workspace.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
0 Me gusta
PhilvK
Bingo! That did it. Thanks.
