Massprop
Massprop
smane
Observer Observer
Message 1 of 8
Massprop
smane
Observer
Observer
Hello
I am working on a project where I need section properties of 18 sided pole shaft. I have created a CAD file in scale and when I enter "Massprop" command then it selects a inside region of interior circle + inside region of outside circle. SO the values that I am getting are not correct
Could you please help
I have attached file for your reference
thanks,
Sandeep
Replies (7)
Message 2 of 8
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Can you please describe your situation again? It's (at least for me) not clear who selects what and which objects you are checking/selecting, which values you get and why you think that they are wrong.
Just to show you what is not clear:
Command _MASSPROP does not select anything, when I start the command I'm asked to select an object.
There is not any circle in the drawing.
If you mean "inside polygon" and "outside polygon" ... there are two of each types, one on layer "P-TOWER" and another one on layer "DEFPOINT", which ones are you referring to?
Which values do you get?
And why do you think that they are not correct?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
smane
Observer
Observer
Hello
I had a CAD file attached to my question, but please see attached here
Also attached is the PDF with my notes/comments
I am available to talk if needed
Sandeep
480-213-8524
From: Autodesk Community [mailto:[email protected]]
Sent: Monday, September 05, 2016 12:39 PM
To: [email protected]
Subject: Re: Massprop (Autodesk Community Subscription Update)
Autodesk_logo
Activity on a Thread You're Following - Description:
http://forums.autodesk.com/html/assets/autodesk_blue_banner.png
Hi smane,
Alfred.NESWADBA (Mentor) posted a new reply in AutoCAD
2013/2014/2015/2016/2017
on 09-05-2016 12:38 PM :
_____
Re: Massprop
/6543093#M139917>
welcome @Anonymous
.autodesk.com!
circle.
- alfred -
lithium.com?subject=Re:%20Massprop> | Accept as Solution
tion=autodesk.prod%7C4ee80ec0%7C3a84f5c0-d72c-43f6-8f70-04f4df7e0d19&dest_ur
l=http%3A%2F%2Fforums.autodesk.com%2Ft5%2Fautocad-2013-2014-2015-2016-2017%2
Fmassprop%2Fm-p%2F6543093%23M139917&ticket=sVGxOwNk4jCV_4032402> | Give
Kudos
tion=autodesk.prod%7C620b0f4a%7C264faa53-cdec-496a-bf08-dc55049dab59&dest_ur
_____
Thanks for being a Autodesk Community member.
Your Autodesk Community Team
You're receiving this because you registered for the Autodesk Community.
Manage your notification settings
or unsubscribe
-message-tracking/ISQG9Y2TGIHYT8>
Select a different language
for
these emails.
To get the most out of your product, visit the Autodesk Knowledge Network
Privacy | Legal Notices
& Trademarks | CCopyright 2016 Autodesk Inc. All rights reserved
Message 4 of 8
Alfred.NESWADBA
Yes, I have seen it, that's why I knew hat there were not any circles in your drawing
Sorry, I don't see a PDF, not in your first post and not in your last one (which is hard to read in the forum)
This here is a public forum (users help users) not a support line you are paying for, so I think you won't get a call from anyone (besides maybe Autodesk if you have created a support case in your Autodesk subscription center).
- alfred -
Alfred NESWADBA
Message 5 of 8
smane
Observer
Observer
Please see attached PDF with notes  (which was plotted from CAD) after Massprop command
Message 6 of 8
Alfred.NESWADBA
>> i need section properties of the region
Not sure if my guessing is correct now. ;(
"the region" is irritating here as "region" is a name of an AutoCAD object type and you have send a drawing with 2 blue regions, if you want to have the mass-properties of the outer region MINUS the inner region you have first to run command _SUBTRACT (to make the inner region an island for the outer one) and then you can run _MASSPROP to get that value.
When you start _MASSPROP and select multiple regions you always get the summed value, AutoCAD does not subtract anything as long as that are separate objects.
HTH, - alfred -
Alfred NESWADBA
Message 7 of 8
john.vellek
Hi Sandeep,
It appears that you have a region (inner"circle") sitting inside another region (outer "circle").
If I subtract the inner region from the outer I can then run MASSPROP.
I did this to both the left hand regions and the right hand regions and got the following results.
Massprop results for left hand regions:
and for the right hand regions:
John Vellek
Message 8 of 8
john.vellek
Hi Sandeep
I am checking back to see if my post or Alfred's helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
