Massprop output no longer working in command line, just in output file
jo2ny
Message 1 of 14
jo2ny
Using latest AutoCad (2025) I can't get the results of massprop to be displayed in the command line. If I say yest to "Output to file" then I get the results in the file, but hitting No doesn't produce any results in the command line.
What am I missing ?
Replies (13)
Message 2 of 14
imadHabash
  • Ensure that your command line settings are set to display output. Sometimes the output might be hidden or truncated.
  • Alternatively, if MASSPROP still isn’t giving you results, consider using the _MASSPROP command (with the underscore), which sometimes behaves differently and might provide output directly to the command line.
Imad Habash
Message 3 of 14
jo2ny
How do I ensure command line settings are set to display output ?
Here's a snip of the comand line :
"Command: _MASSPROP
Select objects: 1 found
Select objects:
Write analysis to a file? [Yes/No] <N>: n
Basically the command finds 1 object ( 2d region ), but exits without any results.
Message 4 of 14
cadffm
share your last  lines of your Log [F2]
AFTER you restartet ACAD
and runned Massprop
(Massprop or _Massprop should be the same in english versions, but .Massprop or _.Massprop could be different in theory / but not in this case here)
Sebastian
Message 5 of 14
jo2ny
I repeated after Autocad restart but I get the same result  (nothing)
pasting stuff here with more context ( created 1 rectange, made it region, massprop)
"Command: rec RECTANG
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]:
Specify other corner point or [Area/Dimensions/Rotation]:
Command: *Cancel*
Command: REG
REGION
Select objects:
1 loop extracted.
1 Region created.
Command: MASSPROP
Select objects:
Command: *Cancel*
Command:
MASSPROP
Select objects: Specify opposite corner: 1 found
Select objects:
Write analysis to a file? [Yes/No] <N>: N"
Message 6 of 14
cadffm
strange. I will do a www research later
EDIT: Nothing, sorry. I am out of ideas, other than reset to default (export settings first), or re-install
Sebastian
Message 7 of 14
imadHabash
This is how it's supposed to be :
Command: MASSPROP
Select objects:
---------------- REGIONS ----------------
Area: 6.5175
Perimeter: 10.2782
Bounding box: X: -7.5295 -- -5.2518
Y: 6.3845 -- 9.2460
Centroid: X: -6.3907
Y: 7.8153
Moments of inertia: X: 402.5218
Y: 268.9957
Product of inertia: XY: 325.5131
Radii of gyration: X: 7.8588
Y: 6.4244
Principal moments and X-Y directions about centroid:
I: 4.4470 along [1.0000 0.0000]
J: 2.8176 along [0.0000 1.0000]
Would you please try the follow :
- Ensure that you have the latest CAD update.
- Open a new & empty CAD drawing file and try again.
- Make sure that you're near 0,0,0 .
- Make sure also that you really select a region shape when you asked to select object while Massprop command is active.
Imad Habash
Message 8 of 14
jo2ny
All of the suggested steps we're taken into account. But still the issue remains unresolved.
Message 9 of 14
cadffm
So,if 2025.1.1 is installed, try the next step: RESET TO DEFAULT
(it will ask for export settings first, use this option),
try it again with the new resetted software.
Not solved?
uninstall/reinstall = Test
same problem?
install latest update = Test
still?
I am out of ideas
Sebastian
Message 10 of 14
pendean
Community Legend
Community Legend
Do this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
And/or... Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
or
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
Message 11 of 14
jo2ny
It turns out that restoring the default settings worked. Not sure why, but it is what it is. Thanks !
Message 12 of 14
jreidKVSUZ
Hit your F2 button. Your information might be hidden behind something.
Mine popped up right away. See below.
Hope this helps!
JRR!
Message 13 of 14
Agnaldo_Ustulim
Observer
Observer
HELOW! TRY TYPING F2 TO OPEN TEXTSCREEN, FIND IT IN ANY CORNER OFF THE WINDOWS DESKTOP, PROBALLY IT´S RESIZED FOR A MINIMAL SIZE,  LIKE THIS ATTACHED IMAGE. REISIZE-IT TO A LARGER SIZE TO VIEW THE RESULTS ON TEXT-SCREEN
Message 14 of 14
cadffm
See post #3
The question is not about a missing textscr
Sebastian
