I just got AutoCAD Civil 3D 2018. Whenever I do a window or crossing selection, there is a very small marker with a blue or green dot in the northeast quadrant of the crosshairs (see picture below in red circle). Is there a way to turn that small marker off?
Thank you.
Solved by imadHabash. Go to Solution.
>> Is there a way to turn that small marker off? <<
Yes of course ... and as mentioned above by changing CURSORBADGE to 1 you can get rid of all badges that provide contextual feedback to reflect the state of many common operations. you can read more here, >> Click <<
hello, changing cursorbadge to the value of 1 did not remove the red dot in the upper left quad?
any suggestions?
The answer is found under the manage tab, thanks!
I do have another issue, as a newer user of autodesk autoCAD civil 3D 2016 I am printing a form to letter size and the right side of the page is "cut off"
It shows on the preview but cuts off the border and part of the bottom too!
Thank you,
Rich
