Hi all,
I can't seem to get the 'dog leg' on the dim leader to show up when we use the text alignment with dimension line. Is there a way to do this?
Give this thread a read and see if it might help
https://forums.autodesk.com/t5/autocad-forum/dimension-styles-leader-landing/td-p/3252502
CADnoob
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Are you using Leaders or Mleaders? Can you share a drawing file that shows how you want the text aligned and how you want the landing to appear?
