Making solid fills visible in "Shade Plot: Hidden"
Hi everyone!
Is it any way possible to print your layout with viewport set to "Hidden" or "Legacy Hidden" and still have solid fills visible in the print? Reason why is sometimes I have a lot of layers with 3d objects on top of each other in different heights in some drawings, and I want the top layers to hide what's beneath them.
Picture 1 is the layout, and also how I want the fills to look like in the print.
Picture 2 is the actual print.
Picture 1Picture 1Picture 2Picture 2
ian.mag
Hey @Anonymous
Have you tried using a 3D viewport? I think that should solve your problem
@ian.mag wrote:
Hey @Anonymous
I just tried, but it only partially works, sadly. "3D wireframe" makes solid hatches, wipeouts and gradients visible, but makes me able to see all objects beneath any 3d objects/meshes.
"3D hidden" hides all solid hatches and wipeouts again.
Alfred.NESWADBA
May I ask what a "3D viewport" is?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
ian.mag
It's not literal. It's the viewport that you use when working with 3d
drawings
ian.mag
Hey @Alfred.NESWADBA
It's not literal. It's actually the viewport used when working with 3D drawings.
