How to convert multiple plot area from single dwg. file to PDF file.
Hi to all, i have single Autocad dwg. file.Which have 45 plot areas of different drawings. I want to convert all these 45 drawings into PDF in single time.Is it possible to choose multiple plot area in single dwg file ?
imadHabash
if your plotting areas will be from Layout's then it's easily will accomplish with PUBLISH command .  >> Click <<
Imad Habash
RobDraw
To do it with that file would take some custom coding. It is much easier using layouts. One layout per sheet. You could then publish all of the layouts to a single PDF.
Rob
I dont understand your solution.kindly clarify.I know to plot one by one
convert to pdf.PUBLISH command is used to convert multiple drawing files to
single pdf.cant convert multiple plot area in single drawing file.if im
wrong kindly clarify.
thanks for your reply.
maratovich
No problems.
Try it:
Revers - Automatic batch printing a multiple format
It is best to attach your sample file. I will make a video for your file.
Here is an example of another file:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
