Macro not working
Macro not working
jriseborough
Macro not working
jriseborough
We have a add on program for Autocad, and part of it is running a macro at startup. All of a sudden the macro in a DVB file does not run, but the macro is there. I am programming illiterate, and not sure what to do.
Here is the error:
Command: _-vbaload Initializing VBA System...
Open VBA Project: "C:/Program Files/Con Span Utility/Con Span Utility 1_0.dvb"
Command: _-vbarun
Macro name: AcadStartup
Execution error
Command: filedia
Enter new value for FILEDIA <0>: 1
Not sure what to even do.
Alfred.NESWADBA
the message "execution error" is not enough info to give you now any suggestions.
I would first contact the creator of the DVB file.
Or upload the DVB here and maybe we can reproduce the issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
leothebuilder
Ask this question in the VBA customization forum, you're likely to get more responses.
http://forums.autodesk.com/t5/visual-basic-customization/bd-p/33
jriseborough
I have posted it over in the VBA area with the file.
Alfred.NESWADBA
to be continued >>>there<<<.
Alfred NESWADBA
