Mac vs PC for AutoCAD
Message 1 of 25
I am looking at purchasing a new Mac or PC but before I did so, I wanted to know if there are any differences between the Mac version of AutoCAD and the PC version of AutoCAD. Are they identical or does one have better functionality over the other?
Replies (24)
Message 2 of 25
leeminardi
AutoCAD for the PC and for the Mac are not identical.  The PC version has some key features that are not available on the Mac.  If there are not extenuating issues I would recommend going with the standard PC version.
See the following link for Autodesk's definition of differences.  Be sure to expand the 2D, 3D, and collaboration details.
https://www.autodesk.com/compare/compare-features/autocad-products
lee.minardi
Message 3 of 25
gotphish001
I'm not positive but I think they are different. The MAC version is missing some features I believe since it is new built from scratch. I at least think that is what I read somewhere.
Nick DiPietro
Cad Manager/Monkey
Message 4 of 25
dgorsman
The main thing to consider isn't core AutoCAD, but what else you are doing.  If you need an AutoCAD vertical product like Plant3D or Civil3D, those are only available for Win.  Similarly, most of the high-end programs like Inventor, Revit, Navisworks, and 3DSMAX are also Win only.  Any other products, do research to see what operating systems are supported; many Mac programs will only run on specific versions so pay attention to details.
Message 5 of 25
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
There are significant differences between the Windows and Mac versions of AutoCAD. Most noticeably, the interface on the Windows product reflects a ribbon interface that was inspired by the Microsoft ribbon introduced into its Office products. The Mac interface has a more "Apple" feeling to it and consists of palettes.
I see that @leeminardi has kindly provided a link to the feature comparison between the two products.  If you really like the Mac platform, realize that when you get an AutoCAD subscription, you are entitled to use both the Windows and Mac versions of AutoCAD.  So you can run the AutoCAD for Mac native and switch to a virtual machine environment to run Windows-based products.  This means you would have to install license of Windows into Bootcamp, Parallels, or VMware Fusion.
Depending on the type of design work you are performing this might give you the best of both worlds.
John Vellek
Message 6 of 25
murray-clack
If you are leaning towards getting a Mac, but still want AutoCAD for Windows, then you should look into getting a Mac and installing a program called "Parallels" which allows you to install Windows OS and any software developed for Windows.
There are a number of YouTube videos that show how well a Mac running Parallels with Windows installed and running AutoCAD works
Message 7 of 25
martti.halminen
One part that comparision page handles rather lightly is customizing AutoCAD with Lisp programs. The Mac version has essentially the same limitations as AutoCAD Core Console:  AutoLISP works, but most of the Visual Lisp extensions (anything requiring ActiveX) won't.
So, whether you are writing programs yourself, or using programs made by others, a large part of the tools are missing.
Message 8 of 25
pendean
Community Legend
Community Legend
1. MAC interface looks nothing like the Windows interface.
2. MAC version has no express tools.
3. MAC version has no ability to add third party add-ons.
4. MAC version has no customizations other than pure LISP.
5. MAC version has no Object Enablers to add if you exchange files with verticals like C3D.
6. MAC version is missing a few other niceities, and 3D is limited.
7. MAC version costs as much as the Windows version. Sounds like a good deal, huh.
Message 9 of 25
dgorsman
Well, for a student with free EDU license learning basic drafting on their fruit-logo'd laptop it's a pretty good deal.  Smiley Happy
Message 10 of 25
pendean
Community Legend
Community Legend
... until they come in here asking why the teacher and other students are using tools they don't have.
Message 11 of 25
I want to thank you all for taking the time to share your thoughts and experience, it's much appreciated.
Message 12 of 25
Se de mucho colegas que después de probar Mac, se devuelven a Windows. Si ya tiene alguna experiencia en Windows, es  mejor que se quede. Dicte un curso en Mac y aunque lo sacamos adelante, fue bastante tortuoso. Sin embargo, como todo es cuestión de costumbre...
Message 13 of 25
I realise this post is nearly a year old but nothing has changed in terms of improving Autocad 2018 for Mac. It gets Fatal Errors when performing the simplest tasks; the Measure command is a joke and the default Toolbars are missing the most basic commands.
Autocad has the audacity to charge a lot of money for this mess?!
I've worked on Autocad for Windows for 20 years with no such problems.  The Mac version is terrible.
Message 14 of 25
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
 I use AutoCAD for Mac 2018 daily and I do not see any crashes.  Would you like to figure out what is going on?  Can you attach a sample file where this is happening?
While not all of the Windows  version features are in the Mac product, most have been included. Which command are you not able to find on a palette?
John Vellek
Message 15 of 25
Hi John
I would like to have the MEASUREGEOM pictorial command added onto the
Dimension menu and the EXTEND command added to the Modify menu, but
separated from TRIM. Is Extend on Windows called Lengthen on Mac?
Also CHAMFER separate from FILLET. The list is endless.
I have tried Tools/ Customize Interface using drag and drop, per command,
but then they still don't appear with their group as pictures on the
grouped toolbar.
As a separate issue a Fatal Error occurred when I was creating a Block, as
I snapped to the Insertion Point. Thereafter the whole drawing file just
spun in limbo for hours and I had to restart the computer.
I don't have a screenshot of that but I did click yes to sending an Error
Report.
I hope you can help. As architects we typically work to deadlines and this
is consuming an enormous amount of time.
Teresa
Message 16 of 25
john.vellek
Hi @Anonymous,
The crash report indicated two errors occurred. The first was corrected in an update. Please verify that your AutoCAD for Mac 2018 if fully up-to-date.  My version is 2018.1 Update Product Version O.48.M.478.  The other error has been identified and is being examined by the Development team. Some customers that report this issue are using anti-virus programs such as CleanMyMac and they are seeing the are when the AutoCAD cache is being cleared out.
As far as adding/moving commands in the menu, in AutoCAD for Mac 2018, you can create a new Panel and add the commands to it with a variety of icon size/orientation formats.
John Vellek
Message 17 of 25
rundoverme
John, I believe you are correct. I do interior design drawings as well as mechanical and 3D drawings and I have been using AutoCad for Mac for several years now and never really had any issues since 2013. I have found that the 2018 version is defiantly better and faster for me so I will never go back to Windows.
Message 18 of 25
moua.thao
I was going to start a new post about a running list of features that the MAC version of AutoCAD doesn't currently have, but seeing as this is a very relatable subject, if the original poster doesn't mind, I'll add them here as I recognize them.
If everyone could add to this that would be great...or if Any autodesk reps could include a list of features that would also be awesome.
Missing specific features in MAC:
-Cannot edit multiline attributes
Message 19 of 25
john.vellek
Hi @moua.thao,
Please do start another thread on this subject.  I will hopefully be able to add a feature comparison matrix article in the near future.
John Vellek
Message 20 of 25
Hi John
Any updates on the matrix? As a training provider we are occasionally asked about the differences between the MAC and Windows versions, as we only train the Windows version I don't know about the MACs.
Anne
