AutoCAD Forum
Logos in AutoCAD - 2.0
10 REPLIES 10
Message 1 of 11
zzz144
860 Views, 10 Replies
In my title blocks, I would like the logo printed to PDF to look nice and crisp as if it came out of illustrator.
- raster/bitmap logos always print terrible.
- I tried converting the logo to DWG and using hatch but that also prints terrible, triangulated,
- I from Illustrator to export to PDF (which looks good) and then inserting that PDF into AutoCAD but the plot/print job is always terrible.
How is this not possible in 2024? There must be a way.
If the PDF is inserted (not imported) into AutoCAD, why does AutoCAD need to re-print it when plotting - just take it and transfer to the the plotted document...
And good luck if your logo has any gradients etc...
10 REPLIES 10
Message 2 of 11
pendean
in reply to: zzz144
Message 3 of 11
zzz144
in reply to: pendean
Thanks but the links are of no help...
Files attached.
I'd like the logo in file 4 to be as crisp as it is in 2.
Message 4 of 11
zzz144
in reply to: zzz144
Here are the other files.
Message 5 of 11
pendean
in reply to: zzz144
Thanks, so what issue are you unhappy with please? These logos are 'about' the same size on my screen, and the topic of your letter-sized PDF is the wall section. See below, page-size and zoomed in
@zzz144 wrote:
...Thanks but the links are of no help...
No idea what you tried then.
Message 6 of 11
zzz144
Tried them all. Even re-creating the logo in AutoCAD. No luck. EMW, WMF, PDF, TIF, PNG, JPG...etc. etc. Both importing as OLE and attaching.
Look at this comparison. Just not good enough for professional software. You may disagree and that is your right. I can list 2720.00 reasons why I think that.
Message 7 of 11
pendean
in reply to: zzz144
Q: why would a recipient of your letter-sized sheet about a wall detail zoom in that close to a letter of a logo?
Just curious, not being argumentative: the topic of the page and target audience might need to carry more weight.
Message 8 of 11
zzz144
in reply to: zzz144
A pdf (made from Illustrator) just inserted (not imported) into AutoCAD displays great.
Plotting/printing the same and its atrocious.
Why not spend a bit of time on improving how this inserted PDF gets simply translated (not re-printed) into the new printout. Look at the attached. Zoom in. Perfect. Why not from AutoCAD.
But we could talk about the fish, I guess.
Message 9 of 11
TheCADnoob
in reply to: zzz144
I always redraw the items in AutoCAD (not import) so that they are native in the DWG. These do well enough.
I completely understand the struggle. I cant stand the way raster images look in dwgs and hard copies. That said, there are complications of having the vector be it in DWG or xref PDF.
I would suggest sending Autodesk feedback on this.
https://www.autodesk.com/company/contact-us/product-feedback
Or you can always try exporting your DWG to Illustrator and doing the printing from there.
CADnoob
Message 10 of 11
tramber
in reply to: zzz144
Converting ? How ? From ?
And why don't you tell about Illustrator capabilities to save in DWG. Did you start from there ?
Message 11 of 11
zzz144
in reply to: zzz144
@TheCADnoob
Right - I take the compromising approach because that is all I have.
I have tried exporting to illustrator but this is time consuming... Especially when you think of 20pages or 100's.
I just wish this would be handled.
@tramber
Yes, I am quite familiar with both IL export and AutoCAD Import and am quite proficient with both programs (I think).
Getting them into AutoCAD is easy - and even getting them look good in AutoCAD is easy - in vector format with with hatch or solid fill etc. - but printing these with even 'good quality' to look like the original (IL->PDF export such as file 2 above) is not possible. Not arguing just wish they would make it work.
AutoCAD Inside the Factory
