Can we turn off the preview we get when selecting any annotation? i.e. see image below.
I don't need to see the preview/thumbnail of what the dimension look like, also i have several and selecting the one i need like so makes it difficult as it seems glitchy, when i scroll through and hover on the one i need it seems to hop on the previous or the next one.
Is there any way we can set this to be a list instead of thumbnails?
Solved by cadffm. Go to Solution.
in AutoCAD are GUI elements called "Toolbars", but you are pointing to the microsoft RIBBO.
Answer: You can not!
System variable GALLERYVIEW is to change this kind of Gallerie View, but not for STYLEs
Sebastian
my bad, i have not used the correct words to describe the issue.
I have changed the system variable GALLERYVIEW from 1 to 0 and it did exactly what i was aiming for.
