Loft guide path
alfinmuharrram97
Loft guide path
alfinmuharrram97
Hey guys. Really need help with this problem. I'm trying to make a 3D solid object with a loft command, but it failed.
(error message 101037). White and orange color is the guide path (it has 2 radius R450 & R382), the yellow color is the profile. I've already tried with curve fit, but the result is not what i am looking for. Hope you guys can help me out with this problem.
VincentSheehan
Maybe split up the guides? Loft then Union the solids.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Valentin-WSP
@alfinmuharrram97 ,
You could also use the EXTRUDE (Path option), and then SUBTRACT.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
leeminardi
Are you sure that you want the 15 radius fillet to be measure in a vertical plane and not a radial plane to the arc?  What you have will yield an elliptical fillet. In addition, there's a discontinuity in the slope at the point between the two arc segments of the polyline. This could be causing some of the problem with loft.
lee.minardi
alfinmuharrram97
Thank you, sir, for your assistance. i find this solution quite simple and I've already try it. again, thank you very much....
alfinmuharrram97
Thank you for your help sir. Sorry, but upper radius only have one radius and should follow the guide curve.
