Load all Materials from the Autodesk Library
lois-pl
lois-pl
I have 3D drawing that I want to apply some specific materials. I know that the Autodesk Material Library has a great variety of materials of all types, i've seen it when I opened some files. But the file I'm working on only shows up a few of them, and I can't find the rest. How do I load everything?
Right now, I can only see about 27 materials, and I also don't understand what was the criteria for these materials to show up instead of other, the materials are pretty random.
Thank you
qnologi
found this...
Manually reinstall the material libraries by running the following MSI files:
(Installation Media)\Content\ADSKMaterials\20xx\CM\MaterialLibrary<version>.msi
(Installation Media)\Content\ADSKMaterials\20xx\ILB\BaseImageLibrary<version>.msi
(Installation Media)\Content\ADSKMaterials\20xx\ILL\LowImageLibrary<version>.msi
(Installation Media)\Content\ADSKMaterials\20xx\ILM\MediumImageLibrary<version>.msi
Note: If installing from a download, the installer will be in the C:\Autodesk folder.
After the installation, an error message and crash may occur after opening the Autodesk software product (and a file). In this case, run a repair for the product via Control Panel > Programs and Features.
qnologi
dmfrazier
It "sounds" like (maybe?) the material browser palette has a filter in effect, so that only a subset of the available materials is shown. Find these buttons in the upper-right corner of the palette:
lois-pl
I checked that! filter is set to show all, and problem persists. But thanks anyway.
@qnologi
sorry I didn't understand your answer.
dmfrazier
Can you show us a screenshot of the Materials Browser for each case (the good and the bad)?
