Plotting - Scale Lineweights Down Per Viewport
Background, we use STB files and ByLayer plot styles exclusively. If we have a layout with multiple viewports displaying parts of the model at different scales (e.g. 1:500, 1:1000 and 1:2000), by default all lineweights will be identical in each viewport.
However, in the 1:2000 case the level of detail is so high that the lineweight thickness is too much and items overlap each other.
I believe the only solution is to set a VP Plot Style for all layers in the 1:2000 viewport. So for example for a layer assigned plot style = Black 35, which means plot that layer in black ink 0.35mm width, I would have to set that layer to plot style = Black 18 in the VP Plot Style column.
Am I overlooking any other solution? Thanks
