AutoCAD Forum
Live Maps
7 REPLIES 7
Message 1 of 8
489 Views, 7 Replies
Live Maps
Will the live map ever be updated? The current one dates from circa 2010.
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
the data you see is from the Bings-service (from Microsoft), you'll have to ask them.
It's nothing Autodesk can do.
This global statement is not correct. It depends on the area you look to and also how close you are. Then you'll see that some regions and scales are newer, some are older.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
So why not change to Google? That's something Autodesk CAN do.
Richard L. King
246 Pinnacle Road
Liberty, ME 04949
860 790 0535
Message 4 of 8
Alfred.NESWADBA
Autodesk had access to Google, but because of license fee's and/or conflicts about regulations/licensing they changed to Bingmaps.
And as I wrote that it depends on areas which is newer and which older, a change to Google does not change the situation. There are some areas where Google is more current, and some where Bingmaps is newer, so again it depends on the area (and zoom depth).
When you see Google Maps as the better imaginary data ... download Google Earth Pro (which is free now, >>>click for info<<<), download the aereal image and use it as reference in AutoCAD.
- alfred -
Alfred NESWADBA
Message 5 of 8
Pointdump
Richard,
In addition to Alfred's always excellent advice, most county and state governments have free downloadable aerial photos.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 6 of 8
stevetamplen
Hello Richard, and welcome to the Forums!
The Expert Elite's have some great solutions posted that should not only answer your question but also give you some excellent alternatives for your map issue.
IF they have resolved your problem/answered your question, please indicate so by clicking Accept as Solution for the post(s) that provided you the answers.
This helps other Community members benefit from reading this thread.
Steve Tamplen
Technical Support Specialist
Message 7 of 8
in reply to: Alfred.NESWADBA
Getting the scale right is a problem using images from Google Earth.
Message 8 of 8
Alfred.NESWADBA
Just one command and 2x3 points: _ALIGN (>>>details<<<) 😉
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
