AutoCAD Forum
Listing detailed block information?
4 REPLIES 4
deltacoolguy
215 Views, 4 Replies
Is there a way to list detailed block information within a drawing and all in one place.  What I really want to see is the block name, which layer it is on (inserted), and the size.  Thanks.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
4 REPLIES 4
pendean
in reply to: deltacoolguy
QUICKPROPERTIES is an option (hover or select object to see info)
PROPERITES left open on a second monitor is another option.
Adding visible FIELDs into attributes inside each and every block to see that info all the time without much effort is the third option.
BTW the C3D forum is over here if these are more C3D objects as there might be even more appropriate options for your variant to explore https://forums.autodesk.com/t5/civil-3d/ct-p/4003
HTH
deltacoolguy
in reply to: pendean
HTH
These do them individually.  I';m looking for something more along the lines of when you enter "-B", ?", and you get a list of all blocks, but I want more info that that gives.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
cadffm
You don't want information about blocks, but for block references!
Command DATAEXTRACTion
Sebastian
Kent1Cooper
How about this?
(command "_.list" (ssget "_X" '((0 . "INSERT"))) "")
Kent Cooper, AIA
AutoCAD Inside the Factory
