List not working in autocad 2017
I used to export pionts from autocad to excel. I would create poly line for the points i wanted to get coordinate then I would press list and all the coordinate would appear and then i would copy it to excel but list option doest seem to work in autocad 2017.
when i press list other stuff appears i have attached a picture.
please advise
thanks
adam
cadffm
Normal return of list for a heavy polyline ("2D POLYLINE" / DXF: POLYLINE)
PLINETYPE
CONVERT
FAQ About Polyline-Types
Sebastian
TheCADnoob
This can also occur if its a 3d polyline. Check properties to confirm its not 3D.
if its 3d use FLATTEN
CADnoob
cadffm
a 3D-POLYLINE list looks different from 2D-Polyline list result, but of course also different from the list of a polyline (LWPOLYLINE). Kudo
Sebastian
john.vellek
Hi @Anonymous,
I am checking to see if the excellent answers by others have helped you to understand why the LIST command returns different results.
I suggest you try using LIST on a LWPolyline, a Polyline, and a 3Dpoly to see the differences.
Others have provided the means to convert between the object types.
Please let me know if you need additional information or clarification. Kudos to all the contributors!
John Vellek
plinetype was = 0
I changed plinetype =  1   I can see the list I wanted to see.
wonderful
thanks guys
tslD7QZ2
Community Visitor
Community Visitor
I used to get a list of polyline like this
at point X= 58.2564 Y= 395.0000 Z= 0.0000
at point X= 68.8838 Y= 390.0000 Z= 0.0000
at point X= 142.1499 Y= 385.0000 Z= 0.0000
at point X= 163.8318 Y= 380.0000 Z= 0.0000
Now I get, this and not all the points even if I press return
at point X4181.470 Y384.000 Z 0.000
at point X4189.395 Y383.000 Z 0.000
at point X4278.954 Y383.000 Z 0.000
at point X4293.222 Y384.000 Z 0.000
at point X4306.308 Y385.000 Z 0.000
at point X4311.132 Y386.000 Z 0.000
please help, this is autocad 17 Plinetype 1,2 or  0 does not change anything.
