Select multiple fit points/vertex / merge multiple fit points/vertex
Hello there,
Is it possible to select multiple fit points/vertex at once?
Not just shift because i need it a lot.
Is it possible to merge multiple fit points/vertex from different lines?
I knowtes when You select 2 lines you can move both of the fit points/vertex.
Wouter
(From the Netherlands)
Sorry for my bad english
cadffm
Is command Stretch a solution for you?
What you want to do with multiple hotgrips?
Sebastian
Hi Sebastian,
Thanks for your reaction,
stretch is the command i am using, but i tink there have to be a beter solution.
Greeting
Wouter
cadffm
No matter what method, the actual effort is to select the points and that would be necessary with every solution?
So I can not see any optimization at all because of this fact.
Unless you have described all the facts worth knowing?
Just upload a simple example file,
Inside: Once the representation of "before" and once the representation of "target" beside it.
Write about your workflow now and your workflow you want to have (exactly).
Sebastian
