AutoCAD Forum
Lisp/ Script for Quickselect and draworder
6 REPLIES 6
2793 Views, 6 Replies
I really have to do some simple task. But I havn't written any LISP/Script yet.
I  have 'n' layers and  want
1- qselect(Quick select)
2- Quick select
Apply to: entire drawing
Object type: Multiple
Properties: Layer
Operator: equal
value: layername
2- Bring all elements oof 'layername' to top. by draworder and
save dwg.
 Any help ?
Tags (2)
6 REPLIES 6
Qselect or filter commands will not work with scripts, try this line at the top of your script to filter for your layer then follow it with the draworder and save
(setq ss1 (ssget "X" ' ((8 . "yourlayername"))))
I tried this already
(defun c:SALL ()
(setq ss1 (ssget "X" ' ((8 . "LC"))))
but  running command SALL  doesn't do anything. No error.
Any lisp to bring  selected objects front or back by using draworder
Try this -
(Defun C:SALL()
(Command "Draworder" ss1 "" "Front" "")
It works. But I cann't use it in Autocad Lt. Is there any method to use it in Lt.
Best to try asking in the LT Forum,
pendean
SELECTSIMILAR then DRAWORDER: both commands explained in HELP.
Technology Administrators
